🎉Community Raffle - Win $25
Join and Win
Difference between results of Linear static and Non linear quasi static.
Hello,
I was carrying out analysis on a model in which load vs deflection results were to be found out.
Material was defined by MATHE card with stress -stretch curve , and some contacts were present.
First I used Linear static loadstep and then I used Nonlinear quasi static step for same model and BCs.
Results of both cases were very much different (more than 50%).
Can anyone tell me what is the case?Is linear static neglecting the effects of contact and material non linearity?
Regards,
Bharat
1 - 5 of 51
