🎉Community Raffle - Win $25
Join and Win
Difference between results of Linear static and Non linear quasi static.
User: "hiranwale_bharat"
Altair Community Member
Updated by hiranwale_bharat
Hello,
I was carrying out analysis on a model in which load vs deflection results were to be found out.
Material was defined by MATHE card with stress -stretch curve , and some contacts were present.
First I used Linear static loadstep and then I used Nonlinear quasi static step for same model and BCs.
Results of both cases were very much different (more than 50%).
Can anyone tell me what is the case?Is linear static neglecting the effects of contact and material non linearity?
Regards,
Bharat
1 - 5 of 51
    User: "tinh"
    Updated by tinh
    Yes, ofcourse Linear Static does not take into account the contact - it is nonlinear, generally all nonlinearity affects including:
    - material nonlinearity: stress is above yield point
    - geometric nonlinearity: stiffness matrix sensitive with geometry deformation
    - boundary nonlinearity: contact
    And also 'static' means no dynamic affect can be captured, so every loads must be applied slowly
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Hi,
    MATHE is a Hyperelastic material.
    HyperElastic materials behave differently compared to isotropic materials and their properties are extracted through strain energy potential.
    Hence linear static will not take account of MATHE card.
    Regards
    Rahul R
    OP
    Hello Rahul and Tinh,
    Thanks for the help,
    Regards,
    Bharat
    OP
    Hello guys,
    What can you say about transient, Random and frequency response analysis. I have heard that random and frequency response are linear analysis. What if these cases have material defined by MATHE and has contacts in it?
    Regards,
    Bharat
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi Bharat,
    FRF, modal, linear transient, random response are linear dynamic when we talk in Solid mechanics terminology.
    You can either do a implicit or explicit dynamic analysis for instance a drop test for nonlinear transient analysis.
