NOTE # 9199
MSGLMT=STRICT is active, all messages will be printed.
You can suppress some less important warning messages by use of
MSGLMT=BRIEF or UNREF (in config file or in the input data).
1 PARAM(s) were set:
CHECKEL,NO
*** WARNING 1932: PSOLID ID 10 is not referenced.
*** WARNING # 7338
GRID 49765 in DSHAPE card 10 is an isolated grid.
*** WARNING # 7338
GRID 49766 in DSHAPE card 10 is an isolated grid.
*** WARNING # 7338
GRID 49785 in DSHAPE card 10 is an isolated grid.
*** WARNING # 7345
Free-Shape detects nonequivalent elements or cracks near GRID 27902.
*** WARNING # 7345
*** WARNING # 7345
Free-Shape detects nonequivalent elements or cracks near GRID 27909.
*** INFORMATION # 815
The total number of rigid elements, whose rotational dependent d.o.f.
are removed because there is no need to constrain those d.o.f., is 18.
NOTE # 1852
AUTOMATIC SCREENING is activated.
Use DSCREEN,AUTO,OFF to disable automatic screening.
FINITE ELEMENT MODEL DATA INFORMATION :
Total # of Grids (Structural) : 75742
Total # of Elements : 304214
Total # of Rigid Elements : 18
Total # of Rigid Element Constraints : 2304
Total # of Degrees of Freedom : 228837
(Structural)
Total # of Non-zero Stiffness Terms : 4423938
Element Type Information
CTETRA Elements : 304214
Load and Boundary Information
FORCE Sets : 1
SPC Sets : 1
Material and Property Information
PSOLID Cards : 2
MAT1 Cards : 1
OPTIMIZATION PROBLEM PARAMETERS :
Objective Function : Minimize Mass
Response Summary :
Number of mass responses : 1
Number of stress responses : 904
Static Subcase Summary :
Subcase ID SPC ID LOAD ID Preloading Subcase ID
10 10 11
Design Parameters Summary :
Total # of free-shape cards : 1
Optimization Parameters Summary :
Maximum Number of Iterations : 30
Convergence Tolerance : 5.0000E-03
Step Size (Shape) : 0.2000
Run Type : Free-Shape Optimization
Restart from previous solution : No
Run at location : Z:/sim_daten/z30/FEM/bijusa1/tesla_X/fem/closeout_freeshape/
Scratch file directory : Z:/sim_daten/z30/FEM/bijusa1/tesla_X/fem/closeout_freeshape/
Free space: 2568.884 GB
Number of CPU processors : 1
MEMORY ESTIMATION INFORMATION :
Solver Type is: Sparse-Matrix Solver
Direct Method
Memory (RAM) Allocated in Preprocessor : 845 MB
Estimated Memory (RAM) for Out of Core Solution : 795 MB
Estimated Memory (RAM) for In-Core Solution : 845 MB
(Note: The Minimum Memory Requirement is limited by Output Module.)
DISK SPACE ESTIMATION INFORMATION :
Estimated Disk Space for Output Data Files : 519 MB
Estimated Scratch Disk Space for In-Core Solution : 1226 MB
Estimated Scratch Disk Space for Out of Core Solution : 1753 MB
BEGINNING OPTIMIZATION SOLUTION ....
OPTIMIZATION HISTORY INFORMATION :
ITERATION 0
*** INFORMATION # 3454
MPC, RBE# (and other rigids) and JOINTG constraints for
subcase 10 will be enforced with lagrange multipliers.
List of Auto-SPC d.o.f.s for loadcase 10
Total number of Auto-SPC d.o.f.s = 2304
Grid No. Component
196 4 5 6
197 4 5 6
198 4 5 6
199 4 5 6
200 4 5 6
201 4 5 6
202 4 5 6
203 4 5 6
204 4 5 6
205 4 5 6
206 4 5 6
207 4 5 6
208 4 5 6
209 4 5 6
210 4 5 6
211 4 5 6
212 4 5 6
213 4 5 6
214 4 5 6
215 4 5 6
216 4 5 6
217 4 5 6
218 4 5 6
219 4 5 6
220 4 5 6
221 4 5 6
222 4 5 6
223 4 5 6
224 4 5 6
225 4 5 6
226 4 5 6
227 4 5 6
228 4 5 6
229 4 5 6
Because of PARAM, PRGPST, 100, Auto-SPC printing is limited to 100 dofs.
(Scratch disk space usage for starting iteration = 1024 MB)
(Running in-core solution)
Objective Function (Minimize MASS ) = 2.55901E-04
Maximum Constraint Violation % = 0.53291E+02
Volume = 2.13250E+05 Mass = 2.55901E-04
Subcase Compliance Epsilon
10 5.206536E+00 2.217249E-10
Note : Epsilon = Residual Strain Energy Ratio.
RETAINED RESPONSES TABLE
Response Type Response Subcase Grid/ DOF/ Response Objective Viol.
User-ID Label /RANDPS Element/ Comp Value Reference/ %
/Model MID/PID/ /Reg Constraint
+Frqncy Mode No. Bound
/Times
10 MASS mass -- -- TOTL 2.559E-04 MIN
11 STRES stress 10 16083 SVM 8.826E+00 < 6.000E+00 47.1 V
11 STRES stress 10 16586 SVM 8.793E+00 < 6.000E+00 46.6 V
11 STRES stress 10 34675 SVM 8.641E+00 < 6.000E+00 44.0 V
11 STRES stress 10 34715 SVM 8.598E+00 < 6.000E+00 43.3 V
11 STRES stress 10 35926 SVM 9.197E+00 < 6.000E+00 53.3 V
MOST VIOLATED CONSTRAINTS TABLE
Response Type Response Subcase Grid/ DOF/ Response Constraint Viol.
User-ID Label /RANDPS Element/ Comp Value Bound %
+Frqncy Mode No.
/Times
ITERATION 1
Objective Function (Minimize MASS ) = 2.55901E-04 % change = 0.00
/Times
+Frqncy Mode No.
/Times
*** WARNING # 7351
The optimization process is terminated due to excessive mesh distortion.
Please check the .HM.elcheck.cmf file for a list of distorted elements.
If the final design is not satisfactory, it is recommended to remesh it
to improve the mesh quality, and perform a second stage optimization.
INFEASIBLE DESIGN (AT LEAST ONE CONSTRAINT VIOLATED).
RESOURCE USAGE INFORMATION
MAXIMUM MEMORY USED 845 MB
IN ADDITION 33 MB MEMORY WAS ALLOCATED FOR TEMPORARY USE
MAXIMUM DISK SPACE USED 1212 MB
COMPUTE TIME INFORMATION
EXECUTION STARTED Tue Aug 30 11:26:27 2022
EXECUTION COMPLETED Tue Aug 30 11:27:49 2022
ELAPSED TIME 00:01:21
CPU TIME 00:00:49
***** END OF REPORT *****
For Useful OptiStruct Tips and Tricks, go to the URL:
http://www.altairhyperworks.com/tips.aspx
NOTE # 9199
CHECKEL,NO
*** WARNING # 7338
*** WARNING # 7338
*** WARNING # 7338
*** WARNING # 7345
*** WARNING # 7345
*** WARNING # 7345
NOTE # 1852
Use DSCREEN,AUTO,OFF to disable automatic screening.************************************************************************
---------------------------------------Total # of Grids (Structural) : 75742
(Structural)
------------------------CTETRA Elements : 304214
-----------------------------FORCE Sets : 1
SPC Sets : 1Material and Property Information
---------------------------------PSOLID Cards : 2
MAT1 Cards : 1************************************************************************
---------------------------------Objective Function : Minimize Mass
Response Summary :
------------------Number of mass responses : 1
Number of stress responses : 904------------------------
10 10 11
---------------------------Total # of free-shape cards : 1
---------------------------------Maximum Number of Iterations : 30
Step Size (Shape) : 0.2000Run Type : Free-Shape Optimization
-------------------------------Solver Type is: Sparse-Matrix Solver
Direct Method
-----------------------------------Estimated Disk Space for Output Data Files : 519 MB
Estimated Scratch Disk Space for Out of Core Solution : 1753 MB************************************************************************
************************************************************************OPTIMIZATION HISTORY INFORMATION :
ITERATION 0
Grid No. Component
196 4 5 6
197 4 5 6
198 4 5 6
199 4 5 6
200 4 5 6
201 4 5 6
202 4 5 6
203 4 5 6
204 4 5 6
205 4 5 6
206 4 5 6
207 4 5 6
208 4 5 6
209 4 5 6
210 4 5 6
211 4 5 6
212 4 5 6
213 4 5 6
214 4 5 6
215 4 5 6
216 4 5 6
217 4 5 6
218 4 5 6
219 4 5 6
220 4 5 6
221 4 5 6
222 4 5 6
223 4 5 6
224 4 5 6
225 4 5 6
226 4 5 6
227 4 5 6
228 4 5 6
229 4 5 6
(Running in-core solution)Objective Function (Minimize MASS ) = 2.55901E-04
Volume = 2.13250E+05 Mass = 2.55901E-04Subcase Compliance Epsilon
10 5.206536E+00 2.217249E-10Note : Epsilon = Residual Strain Energy Ratio.
/Times
------------------------------------------------------------------------------------MOST VIOLATED CONSTRAINTS TABLE
+Frqncy Mode No.
/Times
ITERATION 1Objective Function (Minimize MASS ) = 2.55901E-04 % change = 0.00
/Times
+Frqncy Mode No.
/Times
*** WARNING # 7351
to improve the mesh quality, and perform a second stage optimization.************************************************************************
INFEASIBLE DESIGN (AT LEAST ONE CONSTRAINT VIOLATED).************************************************************************
--------------------------MAXIMUM MEMORY USED 845 MB
MAXIMUM DISK SPACE USED 1212 MB************************************************************************
************************************************************************COMPUTE TIME INFORMATION
------------------------EXECUTION STARTED Tue Aug 30 11:26:27 2022
CPU TIME 00:00:49************************************************************************
Would refining the mesh in concerned regions make a difference?
could you share the .out file?
As you're decresing the stress limit, it is probably harder to converge, as you're pushing it harder.
