P11_SH_SANDW
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
How to set orientation for filament winding composites using type 11 card with mat 25
Plz brief on the use of P11_SH_SANDW card.
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2015
    Hi Jones,
    Use PHIin type prop/type11 card to define orientation.
    before that you need to define a global vector which define the material direction.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2015
    Many Thanks Prakash.
    Could you please briefly explain ur answer
    I'm working on Zone based multi directional and bi-directional plies,in that case how many co-ordinate systems had to be created and How??
    or send help link regarding that if poss.
    Regards,
    Jones
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2015
    Hi Jones,
    You can find more information about TYPE 11 property in RADIOSS starter help.
    Please refer to help to learn more on this.
    In your case, you need one property for one zone.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-50199400-1428648278_thumb.jp
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2015
    can anyone tell me how to define bidirectional ply orientation in optistruct and block 110
    thanks
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2015
    Hi Jessica,
    BiDirectional ply definition is based on Material property. If E11 and E22 are same in MAT8 card then the ply is assumed as bi-directional.
    If the case is reverse, that is E11>> E22 then it is a uni-directional ply.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2015
    HI Prakash,
    I got a doubt reg the same, I have underwent many analysis on Mat 8 card with UD composites....As u are telling that if E11 & E22 are same,Software will consider it as bidirectional. How to assume the difference between UD and BD? will the same be reflected in the result?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2015
    Jones,
    You will see the difference in the results.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2015
    Consider a UD.. The strength will be much greater in the major direction when compared to the minor direction (or less stiffer)
    in the same way, BD will possess similar or almost near strength in both major and minor directions.
Welcome!
Welcome!
