Altair RISE
Nominate Yourself Now!
Problem in initial velcoity
User: "RAMGANESH"
Altair Community Member
Updated by RAMGANESH
Dear Sir,
I am working on the impact analysis of the bullet on the kevlar fibre  i have given the velocity 950 m/s but the simulation is not running properly. kindly provide your guidelines
Thanks
RAM
1 - 30 of 311
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Hi,
    Please make sure that the unit should be consistent.
    In input deck of /BEGIN first two lines of input  unit & working unit should be same.
    Regards
    Rahul R
    User: "RAMGANESH"
    OP
    Dear Sir,
    Units are consistence in my file
    Thanks
    RAM
    How long it is running?
    User: "RAMGANESH"
    OP
    26.06 secs
    <?xml version="1.0" encoding="UTF-8"?>post-34029-0-09510000-1447314599_thumb.j
    looks like Run completed.What problem you are facing?
    User: "RAMGANESH"
    OP
    Yes sir, the run is completed but the bullet is not moving as expected..
    User: "RAMGANESH"
    OP
    I shared my model to you sir kindly check and inform the corrections to be made....
    Hi,
    I don't see any Engine parameter in your deck. Please define common engine parameter & run.
    See attached screenshot for the same.
    Regards
    Rahul R
    <?xml version="1.0" encoding="UTF-8"?>post-36845-0-15203100-1447316750_thumb.j
    User: "RAMGANESH"
    OP
    Dear Sir,
    I have already defined all engine parameters but while generating deck file from hypermesh it doesn't exported.however selected the merge starter and engine icon during export and generated the deck file with engine parameters as you mentioned but while solving geeting zero or negative volume for 3D element error 166
    Thanks
    Ram
    Hi,
    Use the small strain formulation with 8 integration points solid elements to overcome this negative volume error.
    Set Isolid =14 with Inpts =222. Also set Icpre =1 for elastic or visco-elastic material law, and Icpre =2 for elasto-plastic laws.
    This should fix the error and give you good results, let me know if this helps.
    See attached Doc as well.
    Regards
    Rahul R
    User: "RAMGANESH"
    OP
    Dear Sir,
    Same error occurs after the corrections made as per your instruction.
    Thanks
    Ram
    Share the updated file to my FTP.
    Regards
    Rahul R
    User: "RAMGANESH"
    OP
    Dear Sir,
    File shared
    Thanks
    Ram
    User: "RAMGANESH"
    OP
    Dear Sir,
    Did you receive my updated model which i had send yesterday.
    Thanks
    Ram
    Hi,
    I got your model yesterday.Let me take a look and get back to you.
    Regards
    Rahul R
    User: "RAMGANESH"
    OP
    Dear Sir,
    I am awaiting for your guidelines Sir
    Thanks
    Ram
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi Ram,
    As I have told in an earlier post, please check your interface definition,
    Please go through the examples and tutorials available on RADIOSS help for more information.
    User: "RAMGANESH"
    OP
    Dear Sir,
    I have created the interface between the bullet and composite fibre.
    Type 7
    Master part = Bullet
    Slave part = composite fibre.
    I have updated the parts and review the components ..
    What error i have done in this interface please mention Sir,It will be helpful for my current and future work
    Thanks
    Ram
    Altair Employee
    Ram,
    in your model you hvae used type 20.
    Though this will work but there is no master and slave surfaces defined in this contact. Please check.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-07829900-1447653244_thumb.jp
    User: "RAMGANESH"
    OP
    Dear Sir,
    I have used type 20 as well as type 7 and checked the model for the run but the same error occurs.
    Kindly find the screenshot below
    <?xml version="1.0" encoding="UTF-8"?>post-34029-0-07130000-1447653509_thumb.j
    <?xml version="1.0" encoding="UTF-8"?>post-34029-0-45470600-1447653518_thumb.j
    Altair Employee
    Ram,
    You need to create a contact surface and node group for slave and master segments when you use type7
    Selecting components when creating type 7 may not work.
    User: "RAMGANESH"
    OP
    Dear Sir,
    What is the procedure for it?
    Is there is any tutorial for it?
    User: "RAMGANESH"
    OP
    Dear Sir,
    As per your instruction I have created the contact surfaces on the Composite fiber and created entity node sets on the bullet and updated the interfaces then run the simulation but the same error occurs.
    Thanks
    Ram
    <?xml version="1.0" encoding="UTF-8"?>post-34029-0-50797500-1447655419_thumb.j
    Altair Employee
    Hi Ram,
    The contact direction is wrong in your model.
    I suggest you to go through the tutorials on RADIOSS help on how to create contact surfaces and interfaces.
    User: "RAMGANESH"
    OP
    Dear Sir,
    I had run the model which you had sent after creating the engine parameters but my simulation gives results like these
    User: "RAMGANESH"
    OP
    Dear Sir,
    I am expecting results like these
    User: "RAMGANESH"
    OP
    Dear Sir,
    I have given initial velocity of 1300 m/s in z axis but the bullet is not moving as expected .
    I think my error will be on time definition on engine parameters.
    Kindly guide me
    Altair Employee
    Ram,
    check material properties and if you think time is a factor, increase the simulation in \RUN
    User: "RAMGANESH"
    OP
    Dear Sir,
    if i increase the time in \RUN the solving time increases larger
    User: "RAMGANESH"
    OP
    Dear Sir,
    I have tried with different time in \RUN the result is same but the solving time only increases .The bullet is not moving as expected
1 - 30 of 311
