How to create a time variable delay with 3 signals
User: "Ludowick MARIE-CLAIRE"
Altair Community Member
Updated by Ludowick MARIE-CLAIRE
I want to create a variable time delay block with a reference signal, a signal with the delay and a variable time delay.
Have an idea for make this ?
1 - 2 of 21
    User: "Rhonda_20369"
    New Altair Community Member
    Updated by Rhonda_20369
    You may user a C block and write the code.
    The information about C block in PSIM can be found by clicking "Help >> Index", and then, searching for "C block".
    There are example circuits, online help documents, and video tutorials.
    User: "Albert_Dunford"
    Altair Employee
    Updated by Albert_Dunford
    To add to Rhonda's comments, this is tricky if you are doing an analog waveform, if you are doing a logic level signal you can use a comparator with an integrator to track time. then use some other logic elements like flip flops and logic gates to implement your delay.
