🎉Community Raffle - Win $25
Join and Win
NLADAPT DIRECT=yes is not used in my case ?
User: "young"
Altair Community Member
Updated by young
Hi,everybody,
    I need to fix time increment in my load step , have set NLADAPT>DIRECT>YES,and referece this load  in my loadstep. But the solver seems to ignore it and keeps increasing the incerement size.Can somebody give me an advice on what I could do to solve this issue? Thank you very much!
image.png.88b987160432193c23e2e48cd693b6f6.pngimage.png.1758196dcd50ca8353325d44773bedf6.pngimage.png.466fa66d6fb29329e9ade7bf469b17b0.png
1 - 9 of 91
    User: "cfuser"
    Updated by cfuser
    Hi Young,
    could you also share your NLPARM entry, please?
    User: "young"
    OP
    Updated by young
    Hi Young,
    hi cfuser,my NLparm entry likes this, image.png.1697760998fff3026b70f7672f1026b2.png
    User: "FaroukM"
    Updated by FaroukM
    hi cfuser,my NLparm entry likes this, <?xml version="1.0" encoding="UTF-8"?>image.png.1697760998fff3026b70f7672f1026b2.png
    Hi Young,
    It's weird. I ran a non linear static simulation (frictional contact model). I used this configuration (for NLADAPT,  NLOUT and NLPARM respectively)
    image.png.21524420b13f2d1bc21c6b7eb3266411.pngimage.png.55b0e8a70bbf6a74291d3effe7a0e176.pngimage.png.2cc1f93a85ca9b781bc9c1e7912832ab.png
    and It worked well ...
    If it's not confidential, can you please share your model or verify the time increment story in simple model than you can share it ?
    Best regards,
    User: "FaroukM"
    Updated by FaroukM
    To be sure : I repeated the same simulation. Instead of using 0.1 I used 0.05 and it worked well ...
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.989751b5c6a4c5f57373c22bcb53dad8.png
    Please keep me in touch.
    User: "young"
    OP
    Updated by young
    Hi,
        Thank you for your reply, I tried the configuration as you said, but it  not works very well,still keeps increasing the incerement size.I try a simple case likes this:
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi,
    Increment adjustment is automatic by default PARAM>EXPERTNL>AUTO. Try with PARAM>EXPERTNL>NO instead.
    User: "young"
    OP
    Updated by young
    Hi,
    Hi,hyperman,
           I have tried this setting as you said,it worked well, the increment size is fixed.Thank you very much.
         But, in other case ,I haven't keep expernel>no, just be sure the DTmax equals to DTmin, the increment can be fixed, so 8s this setting( PARAM>EXPERTNL>NO) only necessary in some cases?
           Looking forward your reply.
    The increment can be fixed using either:
    • DTmax=DTmin
    • PARAM>EXPERTNL>NO
    However NLADAPT>DIRECT>YES does not work for some reason.
    User: "young"
    OP
    Updated by young
    • DTmax=DTmin
    • PARAM>EXPERTNL>NO
