NLADAPT DIRECT=yes is not used in my case ?
Hi,everybody,
I need to fix time increment in my load step , have set NLADAPT>DIRECT>YES,and referece this load in my loadstep. But the solver seems to ignore it and keeps increasing the incerement size.Can somebody give me an advice on what I could do to solve this issue? Thank you very much!
Hi Young,
could you also share your NLPARM entry, please?
0 -
Altair Forum User said:
Hi Young,
hi cfuser,my NLparm entry likes this,
0 -
Hi Young,
It's weird. I ran a non linear static simulation (frictional contact model). I used this configuration (for NLADAPT, NLOUT and NLPARM respectively) :
and It worked well ...
If it's not confidential, can you please share your model or verify the time increment story in simple model than you can share it ?
Best regards,
0 -
Thank you for your reply, I tried the configuration as you said, but it not works very well,still keeps increasing the incerement size.I try a simple case likes this:
0 -
Increment adjustment is automatic by default PARAM>EXPERTNL>AUTO. Try with PARAM>EXPERTNL>NO instead.
0 -
Hi,hyperman,
I have tried this setting as you said,it worked well, the increment size is fixed.Thank you very much.
But, in other case ,I haven't keep expernel>no, just be sure the DTmax equals to DTmin, the increment can be fixed, so 8s this setting( PARAM>EXPERTNL>NO) only necessary in some cases?
Looking forward your reply.
0 -
The increment can be fixed using either:
- DTmax=DTmin
- PARAM>EXPERTNL>NO
However NLADAPT>DIRECT>YES does not work for some reason.
0 -
- DTmax=DTmin
- PARAM>EXPERTNL>NO
