🎉Community Raffle - Win $25
Join and Win
Embed and Smartworks iot problem
User: "Jeff_wu"
Altair Community Member
Updated by Jeff_wu
Hi Team, I read Embed and SmartWorks IOT tutorial and try to configure my device. But the SmartWorks interface in the tutorial has been completely changed so I have some problems. I have performed some steps in SmartWorks so far, create space,category,things and model.But I don't know how to configure JSON and MQTT in Embed, can you guide me how to configure it? Thank you.
1 - 4 of 41
    User: "Girish Karamadi_21849"
    New Altair Community Member
    Updated by Girish Karamadi_21849
    Hi Robbert,
    Are you trying to use Arduino and ESP8266 to send the data to Smartworks??
    https://altairsmartcore.com/
    Click on that above link. You would need to have an account to set up the device on smartcore.
    create a device and configure the MQTT for instance as shown below on smartcore . Once you create the device copy the device ID to JSON block of Embed.
    Next on the MQTT block of Embed copy the API key of smart core to topic and user name of MQTT block in Embed . Password would be same as you set it on smartcore when you configure MQTT .
    Let me know if anything is required.
    Regards,
    Girish
    User: "Steven Fine"
    Altair Employee
    Updated by Steven Fine
    Based on some of your discussion, you MIGHT have signed up for the NEW IoT platform at studio.swx.altairone.com.  That demo refers to our OLD IoT platform as you have it shown.  I don't know if the embed example will work with the new platform... the JSON messages are much different.
    User: "Jeff_wu"
    OP
    Updated by Jeff_wu
    Hi Robbert,
    Regards,
    Girish
    Hi Girish,
    Thanks for your reply. I don't have any direction in NEW IoT platform and not even sure if I can communicate with SmartWroks using JSON and MQTT from Embed
    I would really appreciate it if the development team could update the tutorial document for the latest IoT platforms.
    User: "Jeff_wu"
    OP
    Updated by Jeff_wu
    What you said is absolutely right. This is the biggest problem I currently encounter when I want to use Embed for IoT in NEW platform.....
