Radioss 2022.2 Student version does not show the h3d after run
Hi All
I built up a model in Radioss in Hyperworks 2022 , and when I clicked the Run button, the old Hypermesh run management opens up, but when I hit run, nothing happens and no h3d file is generated. I also dont know in which folder it is supposed to be saved! and I can not also open any contour file, since after the run, no new tab is generated. what would be the problem?
p.s. I guess in student version we don't have compute console. is that correct?
1 - 1 of
11
Hello Farzad,
Can you please take a look at the following Knowledge base article and see if it helps?
Why do I not have my result *h3d file after Radioss finishes successfully?
Regarding the compute console question, as checked here: Student Edition Products, compute console is unavailable on the student version.
If after that, the problem persists, please, share the model here, if you can.
Regards, Guilherme.
