Altair RISE
Nominate Yourself Now!
Start consecutive independant optimizations
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I have prepared several independant Optimization studies based on the same model, each of them takes 2 to 3 hours to complete the maximum of 400 iteration cycles.
Is there a possibility to evaluate each task consecutively by using one command?
I would like to avoid to start the evaluation of each task seperately, in order to run all tasks overnight.
The Optimizations are fully prepared and only require to be started by hitting the 'Evaluate Task' button. See the attached screenshot for further Info.
Thanks for your suggestions in advance!
Cheers,
Felix
1 - 4 of 41
    Altair Employee
    OP
    Unfortunately, you cannot evaluate multiple approaches at once. However you can run the study in batch which will eliminate the need for you to click on evaluate for each approach. Hope this helps.
    Altair Employee
    OP
    Hello,
    Thank you for your quick response.
    Can you provide some more Information on how to run several studies batchwise?
    This is exactly what I was asking for.
    Wich settings are required to achieve the workflow mentioned above?
    Best regards,
    Felix
    Altair Employee
    OP
    In online help, under 'Invoking HyperStudy' section batch commands are listed for different OS. As for picking what to run in batch; in the UI; if you click on the study name; you will see that one of the tabs is called 'Batch Tasks'. In this tab; you can pick which approaches you'd like to run batch. Hope this helps.
    Altair Employee
    OP
