I have prepared several independant Optimization studies based on the same model, each of them takes 2 to 3 hours to complete the maximum of 400 iteration cycles.
Is there a possibility to evaluate each task consecutively by using one command?
I would like to avoid to start the evaluation of each task seperately, in order to run all tasks overnight.
The Optimizations are fully prepared and only require to be started by hitting the 'Evaluate Task' button. See the attached screenshot for further Info.
Thanks for your suggestions in advance!
Cheers,
Felix
