Altair RISE
Nominate Yourself Now!
element quality check
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Please check the attached images for error elements while manual meshing.
Here element radius is very much less than element thickness, therefore this shell element gives error while running.
Is there any way/ quality check to identify this while meshing.
If not how to add this check: element radius/thickness ratio criterion to the quality check settings, so that user may check it while checking for other criteria (e.g. in F10 panel).
Thank you
1 - 4 of 41
    User: "Shivani Tiwari"
    Altair Community Member
    Updated by Shivani Tiwari
    If radius that much small then you can defeature it
    User: "tinh"
    Updated by tinh
    It's intersting! I will try checking this factor.
    What solver are you using?
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Show us error message? Did you use 2nd order shell elements?
    Altair Employee
    OP
    hey
