Please check the attached images for error elements while manual meshing.
Here element radius is very much less than element thickness, therefore this shell element gives error while running.
Is there any way/ quality check to identify this while meshing.
If not how to add this check: element radius/thickness ratio criterion to the quality check settings, so that user may check it while checking for other criteria (e.g. in F10 panel).
Thank you
