Composite Shuffle Optimization with plys not in 45 -45° angle
Hey all,
currently I am working on a composite optimization process that involves no 45 and -45° plies.
What I experienced was, that with the step 3 (shuffle optimization), optistruct did not consider my constraint of maximum ply successor. Is this a knows issue?
Additionally, why can't we define pairing constraints between other plies than the 45 and -45° ? Is there a physical reason why you would do that just with 45 and -45 ?
Thanks and best regards /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Merula
Sure. .out attached... we noticed that the constraint was violated, so we increased it to see if it would have any results...
I attached the .html as well for you to see what changes with every iteration...
Unfortunatly I cant share the .fem file.
Thanks Prakash.
Hi @Merula
Optimization finished in two iterations and from .out file I couldn't find anything.
Is it possible to share the model file?
As promised, here are the files.
Hi @Merula
If you look at the stack after shuffling, only 0, 90 plies followed MAXSUCC rule but rest were ignored (0, 60). This is intended. The current mechanism accepts only 0/90/45/-45
Developers are already working on in to make a more robust optimization tool.
as far as I understood this, maxsucc is a constraint from manufacturing side... Why is it limited to 0 90 45 -45 ? Is there a physical reason for this or just a TODO in the feature list?
Best regards
Hi @Merula
Could you please the .out file of shuffling part?
Pairing 45 and -45 reduces in-plane shear stress.
