Overestimation of stiffness of porous structures
Mudassar
Mudassar Altair Community Member
edited April 2024 in Community Q&A
Hi,
I am trying to find the stiffness of porous structures in SimSolid and compare it with the FEA method. For smaller models, values by both methods are quite close. However, in a larger model, the stiffness value by SimSolid is much higher; more than 2 times compared to FEA results. Please see the screenshot of the solution parameters that I am using as well as the model info. Could it be the limitation of model size/complexity in SimSolid? or do I need to change any parameters?
Thanks for your help.
Regards,
Mudassar
Welcome!
Answers
  • GirishM
    GirishM
    Altair Employee
    edited April 2024
    Can you try to create a local group for the lattice and give it high refinement level and also check adapt to thin solids?
  • Mudassar
    edited April 2024
    I have tried this method. The stiffness value reduced slightly but is still very high. Any other way to fix that?
  • GirishM
    GirishM
    Altair Employee
    edited April 2024
    Can you please create a ticket for support and attach the model to investigate?
  • Mudassar
    edited April 2024
    Ok, will do that. Thank you.
Welcome!
Welcome!
