I am trying to find the stiffness of porous structures in SimSolid and compare it with the FEA method. For smaller models, values by both methods are quite close. However, in a larger model, the stiffness value by SimSolid is much higher; more than 2 times compared to FEA results. Please see the screenshot of the solution parameters that I am using as well as the model info. Could it be the limitation of model size/complexity in SimSolid? or do I need to change any parameters?
Thanks for your help.
Mudassar
