🎉Community Raffle - Win $25
Join and Win
Output SPCFORCE
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I want to output SPCFORCE of my constraint
Step 1
I have set
Step 2
I output boundary total force and I don't want to separate direction.
So I set Mag of here
Step 3
I choose nodes in my constraint
Step 4
Then I output all of them data like this then do the summed of the all nodes data so I can get the area total force of my constraint
I just want to ask. Do I use the SPCFORCE right?
And other questions are about:
1. If my constraint area is 700mm^2 but I just want to see the constraint area force about 350mm^2
So if I just output the choosen area 350mm^2 it also output this area's SPC force. Then when I summed them it is my area 350mm^2's SPC force.
Is this idea right?
2. I have found that SPCFORCE can't support small displacement?
But at this time when I output it will have value.
3. If I use Option→Set  then choose the SPC which I set
How should I read the set's SPC force in hyperview.
1 - 3 of 31
