How to export surface pressure from AcuFieldView or AcuSolve to FEA solvers
Altair Forum User
Altair Forum User
Altair Employee
edited June 2021 in Community Q&A
Hi,
I would like to export these pressure values from AcuFieldView or AcuSolve to FEA solver, how can i do that..?  Please help me regarding the same.
Regards,
Sandeep P
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited November 2017
    Hi Sandeep,
    Please find the attached documents which explains how to map pressure to a structural solver.
    let me know if you face any problems in mapping.
    Regards
    Ravi Harti
  • Junta_20361
    Junta_20361 New Altair Community Member
    edited December 2018
    hello guys,
    im having an issue while using AcuSolve cmd promt.
    i can not create variables nodes neither run the command acuPython acuGetNodeSubset –h.
    The programs show me the error in the picture below.
    can you guys help me.
    P/S: i already placed acuGetNodeSubset file in my working directory.
  • acupro
    acupro
    Altair Employee
    edited January 2019
    If you first use 'cd' to go into the directory where you placed the acuGetNodeSubset python script itself, you should be able to use
    in that directory, rather than issuing it from the 'Documents' directory as in your snapshot.
  • Junta_20361
    edited January 2019
    Thank you so much!
  • sfk1229
    sfk1229 Altair Community Member
    edited August 2020
    I couldn't find  acuGetNodeSubset python code in my installation directory or anywhere else in my pc. So, Where can i get acuGetNodeSubset Python file.
    It would be great if you help me out with this.
  • acupro
    acupro
    Altair Employee
    edited August 2020
    acuGetNodeSubset should be in the /script/ directory of the installation.
  • sfk1229
    edited August 2020
    Tq for reply. I couldn't find it my installation directory.  Luckily I got it from Forum memeber.
  • acupro
    acupro
    Altair Employee
    edited August 2020
    Just curious - which AcuSolve version are you using, and on which OS?
  • Vignesh  Lakshmanan
    Vignesh Lakshmanan Altair Community Member
    edited June 2021
    Hi Everyone,
    GetNodeSubset gets the data at the nodes. Is it possible to get data at cell centers?
    Regards
    Vignesh
  • acupro
    acupro
    Altair Employee
    edited June 2021
    Hi Everyone,
    Regards
    Vignesh
    AcuSolve stores the data at the mesh nodes rather than the cell centers.  What are you wanting to do such that you want data at a location other than the mesh nodes?  In other words, why would the data at the mesh nodes not be sufficient?
    edited June 2021
    Thanks for your reply. IMO there should be no difference between the two , since CFD works on conservation principles. I cannot disclose much, but I need to map pressure data (from another CFD code) to structural mesh in HM. I am getting some deviation in my results. Hence, I want to check if i can get the same data from Acusolve and try mapping in HM and may be the deviation is gone.
  • acupro
    acupro
    Altair Employee
    edited June 2021
    If you only need to map/interpolate the AcuSolve data onto another mesh, you should be able to use the load mapper and/or linear interpolation process within HyperMesh using the nodal data from AcuSolve directly, rather than going through two different interpolations.  There are a few different topics on that in other forums describing the process to extract the surface data from AcuSolve results and map/interpolate in HyperMesh - or refer to the initial question and response above in this topic.
    You could potentially use the acuInterp utility within the AcuSolve distribution to interpolate the data to a point cloud, but you would need to build that point cloud as there is no AcuSolve script/utility to do that for you.
Welcome!
Welcome!
