Altair RISE
Nominate Yourself Now!
implicit modeling disappear problem
User: "jsh"
Altair Community Member
Updated by jsh
Hi, I have a question about Altair Inspire implicit modeling.
I am using version 2023.1 and have a student license.
I am trying to convert a designed body to a lattice structure but it keeps failing.
I have an issue where the moment I select implicite modeling, the model disappears. My model disappears the moment I select any of the options: surface, planar, strut, etc.
Even when I select primitives, none of them are displayed on the screen.
How can I fix this?
This is a relevant screenshot
1 - 7 of 71
    User: "Ximena"
    Altair Employee
    Updated by Ximena
    Hi!
    First of all, how did you create the cube and the plates of your file? Are those from an external file or did you create them using the geometry tools?
    - Have you try to run a simple structural analysis in your model?
    - Could you try first creating a primitive cube or cylinder and then a lattice on it?
    - Does it happen with all your files or only this this one?
    Kind Regards,
    User: "jsh"
    OP
    Updated by jsh
    Hi!
    Kind Regards,
    Sorry for the late reply.
    I used inspire's geometry tool for the cube and plate in the screenshot, but I have the same problem when I import an external file.
    Whether I create a basic cube, sphere, or cylinder, the moment I apply explicit modeling, it doesn't show up in the display.
    I have uninstalled and reinstalled inspire and the same problem occurs.
    I am attaching a screen recording of inspire. Can you confirm what the problem is?
    Thanks.
    User: "Ximena"
    Altair Employee
    Updated by Ximena
    Thanks.
    Could you skip the step of creating a Primitive and apply the lattice to the originally created cube?
    Check the video attached
    User: "Rodolfo Peralta"
    New Altair Community Member
    Updated by Rodolfo Peralta
    Good evening. I have exactly the same problem, and I'm not able to resolve it. I've followed the video exactly, to the same result, the implicit part never appears.
    How can I fix this?
    Thank you very much.
    User: "jsh"
    OP
    Updated by jsh
    How can I fix this?
    hello
    I still haven't solved this issue.
    However, if I save the model as stl, restart inspire and load the stl file, I can see that implicit modeling is applied.
    It seems to be a display issue.
    Thanks.
    User: "Justus Reuter"
    Updated by Justus Reuter
    Have the same Problem RTX 3070 yesterday everything worked now nothing visible why ?
    Kind Regards,
    Kind Regards,
    I have completely reinstalled Windows and now everything is working again. I have no idea why the problem occurred.
