Non Linear Analysis
Hello!
I'm trying to perform an analysis on Opstitruct. On the increment 6, the solver stopped and finished the analysis. But, I request 20 increments. The output file doesn't show me the because of this. There is no error message. In the end there is just a message 'Job Completeted' and none message about the convergence of analysis. The program doesn't made the H3D file too. What can i do? Can i continue from the increment 6?
Thanks!
1 - 1 of
11
HI @Rickson Thiago Fernandes
I can see that analysis is not completed in the .out file. Do you have an updated .out file?
You can limit the maximum time step using NLADAPT.
