Altair RISE
Nominate Yourself Now!
no se carga el programa
User: "FRANKLIN SUNTAXI"
New Altair Community Member
Updated by FRANKLIN SUNTAXI
 No puedo utilizar el programa Altair inspire 2024, al iniciar el programa tengo este mensaje.
Error al cargar C:/Program Files/Altair/2024/Inspire2024/hwx/plugins/freedom/gui/win64/bin/hwfdmplugin.dll: Error en una rutina de inicialización de la biblioteca de enlaces dinámicos (DLL).
1 - 3 of 31
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    hola,
    if your CPU is too old, you might get some issues with installing Inspire 2024.
    Another thing that you need to check is if your GPU is supported or not and if its graphic drivers are up-to-date.
    Additionally, Inspire requires dedicated graphic card to work properly, so you need to check if your graphic card is officially supported. But in any case, check and update the graphic drivers.
    User: "mcampano10"
    con el inspire form o elinstruse me da este error
    Error loading C:/Program Files/Altair/2024.1/InspireForm2024.1/hwx/plugins/freedom/core/win64/bin/hwfdmplugincore.dll: Error en una rutina de inicializaci�n de biblioteca de v�nculos din�micos (DLL).
    he cambiado la configuración de la tarjeta , no hay manera
    User: "mcampano10"
    Error loading C:/Program Files/Altair/2024.1/InspireExtrude2024.1/hwx/plugins/freedom/core/win64/bin/hwfdmplugincore.dll: Error en una rutina de inicializaci�n de biblioteca de v�nculos din�micos (DLL).
    QUE HACER ?????????
