🎉Community Raffle - Win $25
Join and Win
(Solved) Turbulence model and Y+ value
User: "Junta_20361"
New Altair Community Member
Updated by Junta_20361
Hello expert,
I am new to CFD and i have some questions about turbulence model and Y+ value.
  1.  There is a lot of turbulence model provided in AcuSolve: Spallart Allmaras, K-epsilon, K-omega,...
    - So which model should be used for some specified case?
  2.  The value Y+ is used to determined the 'first cell height' while meshing.
    - what is the value of Y+ should i used to calculate 'first cell height'?
    - Does it depend on type of flow (internal/ external) or chosen turbulence model?
the following picture was taken in HyperMesh > Utility browser.
Thank in advance!
Best regard!
1 - 4 of 41
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi,
    The y+ value depends upon the accuracy of solution required in the near wall region for your simulation and also the turbulence model chosen. Spalart-Allmaras, the standard acusolve wall function, can handle y+ values below 300.
    User: "Junta_20361"
    OP
    Hi,
    hi Nimisha,
    Thanks for your detail answer.
    User: "acupro"
    Altair Employee
    Updated by acupro
    You'll achieve better accuracy with lower Y+ values - at the cost of more mesh and longer simulation runtime.  For example, you'll typically get a more accurate solution with Y+ = 20 than you would with Y+ = 100.  However, maybe the level of accuracy at Y+ = 100 is enough for your purposes.  That's where it becomes 'engineering' instead of just running a simulation.  You can run a mesh sensitivity study to see how the solution of interest changes as you modify the meshing parameters.
    User: "Junta_20361"
    OP
    thanks Acupro,
    very detail answer.
    best regards!
