🎉Community Raffle - Win $25
Join and Win
Maximizing Shear Strain
User: "mesun_20785"
Altair Community Member
Updated by mesun_20785
Hi ;
How can i set a topology optimization in which i want to force some part of (some of the components of desing) my design to have maximimum shear strain while the other connected region as design space.
Thanks in advance
1 - 10 of 101
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    You then need to assign a certain region as design space and certain other regions as non design space,
    to define a Non-Design Space for optimization, you need to create a separate component and property. It is necessary to either separate the areas on a geometry level (i.e. before meshing) or on the element level (after meshing).
    After meshing, you still can move areas to the Non-Design component. Please use the 'organize' function within HyperMesh.
    The following movie shows all necessary steps on a simple part:
    http://screencast.com/t/AO8bdmh9E7
    User: "mesun_20785"
    OP
    Hi;
    Thank you very much for your answer but my intention was to ask to setup a topology optimization for one region of my design.I already organized my components and mesh region.
    I want to maximize Shear Strain of Design Space..but how any idea?
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi,
    Maybe you can use exclude elements option when creating response for strain? Try this.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-70634100-1424855776_thumb.jp
    User: "mesun_20785"
    OP
    Hi Prakash ;
    Firstly thank you for your answer..But i want to increase  'shear strain' in my non-desing domain.such that
    I created my model design domain/component and non-desing Component.I want to increase or maximize the shear strain energies (objective)  of non-design elements targeting  the topology of design space.
    I hope i am clear..I want to find best topology of my design space that maximize/increase the shear strain of non-design elements.
    Or i want to know if there is any option maximize shear strain/shear strain energy/ESE of any component.
    Regards
    Altair Employee
    Hi,
    First of all, using strain as a response is not at all recommended for a topology optimization.
    You can request shear strain through Control cards>> Strain>> type Shear and this can be used as a response.
    But, stress and strain are not recommended for topology optimization.
    User: "mesun_20785"
    OP
    Hi
    Thank you very Much
    But how about minimizing Compliance ( strain energy ) ( in Other Words maximizing stiffness) maybe i used wrong terminology .. I want to maximize strain energy to have Much Flexible structure ..but how..
    I want to learn on solutıon of simple rectangular domain to get idea or methods to increase the flexibility of my design With best topology ( material distribution)
    Thanks
    Altair Employee
    Hi,
    You can use compliance as a objective response which can be defined for entire structure or property or material and you can try with volume fraction as an optimization constraint.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-94879000-1425278535_thumb.jp
    User: "mesun_20785"
    OP
    Hi thanks;
    As far as i searched minimizing Compliance gives stiffer structure.. So should i minimize Compliance? To have Much more Flexible structure ( beam for example)
    Thanks
    Regards
    User: "mesun_20785"
    OP
    Sorry should i maximize Compliance ? Does it work?
    Altair Employee
    Hi,
    Yes, maximizing compliance will result in a less stiffer structure.
