🎉Community Raffle - Win $25
Join and Win
EDEM crashed with API
User: "Raheem Sterling_22160"
Altair Community Member
Updated by Raheem Sterling_22160
Hi,
When I modified some code of my api, just delete some custom properties and added some values to preference file, and then when I run the simulation with new API, EDEM crashed. When I debug the code, the value of timestepdata.time was a wired value. I can't locate where was wrong. Thanks
1 - 12 of 121
    User: "RWood"
    Altair Employee
    Updated by RWood
    Hi,
    That's a perfectly valid value for the time, why do you think it's weird?
    You would have to debug line by line to see where your issue is. If you're saying the only new bits of code are custom properties and reading prefs file values, start there. It's very easy to read in incorrect values in a preference file.
    Richard
    OP
    Hi,
    Richard
    Hi Richard,
    Because I saw time was a negative value.
    Regards!
    User: "RWood"
    Altair Employee
    Updated by RWood
    Hi Richard,
    Regards!
    Ah, I missed that. Not sure I've seen a negative time value in EDEM before, impressive!
    I'd still debug a line at a time and check all your values for the source of your error
    OP
    Hi Richard
    Thanks, because sometimes the simulation can finish, and crash happens at the beginning of simulation, I have debugged the code and the values read from the preference file were correct. That's why I am confused.
    Regards!
    User: "RWood"
    Altair Employee
    Updated by RWood
    Hi Richard
    Regards!
    I'm intrigued now. I'm not guaranteeing anything but if you can post your code I'll take a quick look
    OP
    Thanks Richard, I've attached the cpp file and preference file, please check out, just inform me if you need edem file.
    User: "RWood"
    Altair Employee
    Updated by RWood
    Can you send the rest of the src? If you're following the usual API plugin style that would be the .h for that class and another .cpp for the macros
    OP
    I've added the rest of code and edem file which crashed.
    Regards!
    User: "RWood"
    Altair Employee
    Updated by RWood
    Regards!
    I can't see any attachments at all, anymore
    OP
    Sorry, I upload again.
    User: "RWood"
    Altair Employee
    Accepted Answer
    Updated by RWood
    Lines 323 to 326 you're adding to four components of the custom property "InitialOverlap" but it only has one element in the definition on line 740. That needs increasing to 4. That's leading to completely unknown behaviour because you're writing to memory that you have no idea about and the effects are completely unpredictable ...like negative time
    OP
    Ah, I missed this, thanks for pointing out this problem.
