🎉Community Raffle - Win $25
Join and Win
Error: Time Step less or equal DTMIN for Solid Elements
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
i've got Error: Time Step less or equal DTMIN for Solid Elements...
here's my log:
 FINAL TIME . . . . . . . . . . . . . . . . . . .   10.00000
 TIME INTERVAL FOR TIME HISTORY PLOTS . . . . . .  0.1000000E-02
 TIME STEP SCALE FACTOR . . . . . . . . . . . . .  0.9000000
 MINIMUM TIME STEP  . . . . . . . . . . . . . . .   0.000000
 BRICK TIME STEP SCALE FACTOR . . . . . . . . . .  0.9000000
 BRICK MINIMUM TIME STEP. . . . . . . . . . . . .   0.000000
 MIN. TIME STEP FLAG (1:STOP RUN, 2:DELETE BRICK)     1
 QUAD TIME STEP SCALE FACTOR. . . . . . . . . . .  0.9000000
 QUAD MINIMUM TIME STEP . . . . . . . . . . . . .   0.000000
 MIN. TIME STEP FLAG (1:STOP RUN, 2:DELETE QUAD).     1
 SHELL TIME STEP SCALE FACTOR . . . . . . . . . .  0.9000000
 SHELL MINIMUM TIME STEP. . . . . . . . . . . . .   0.000000
 MIN. TIME FLAG (1:STOP, 2:DELETE, 3:SMALL STRAIN)    2
 TRUSS TIME STEP SCALE FACTOR . . . . . . . . . .  0.9000000
 TRUSS MINIMUM TIME STEP. . . . . . . . . . . . .   0.000000
 MIN. TIME FLAG (1:STOP, 2:DELETE). . . . . . . .     0
 BEAM TIME STEP SCALE FACTOR. . . . . . . . . . .  0.9000000
 BEAM MINIMUM TIME STEP . . . . . . . . . . . . .   0.000000
 SPRING TIME STEP SCALE FACTOR. . . . . . . . . .  0.9000000
 SPRING MINIMUM TIME STEP . . . . . . . . . . . .   0.000000
 AIRBAG TIME STEP SCALE FACTOR. . . . . . . . . .  0.9000000
 AIRBAG MINIMUM TIME STEP . . . . . . . . . . . .   0.000000
 MIN. TIME FLAG (1:STOP). . . . . . . . . . . . .     0
 INTERFACE TYPE 7 TIME STEP SCALE FACTOR. . . . .  0.9000000
 INTERFACE TYPE 7 MINIMUM TIME STEP . . . . . . .   0.000000
 MIN. TIME FLAG(1:STOP, 2:REMOVE NODE FROM INTERF)    0
 FVMBAG TIME STEP SCALE FACTOR. . . . . . . . . .  0.9000000
 FVMBAG MINIMUM TIME STEP . . . . . . . . . . . .   0.000000
 PRINTOUT CYCLE FREQUENCY . . . . . . . . . . . .  -100
 RESTART CYCLE FREQUENCY. . . . . . . . . . . . .       5000
 MAXIMUM RESTART WRITE BEFORE OVERWRITE . . . . .     0
 INVERS: INPUT DECK VERSION . . . . . . . . . . .   120
 ITTYP : FLAG FOR TYPE OF T-FILE. . . . . . . . .     4
 TIME FOR FIRST ANIMATION-FILE PLOT . . . . . . .   0.000000
 TIME INTERVAL FOR ANIMATION-FILE PLOTS . . . . .  0.1000000E-02
 SENSOR FOR ANIMATION-FILE PLOTS. . . . . . . . .          0
 TIME INTERVAL FOR SENSOR ANIMATION-FILE PLOTS. .   0.000000
 VARIABLE SAVED ON ANIMATION FILES (1: YES) :
      PLASTIC STRAIN. . . . . .     0
      DENSITY     (SOLID ONLY).     1
      SPECIFIC ENERGY . . . . .     0
      HOURGLASS ENERGY. . . . .     0
      TEMPERATURE (SOLID ONLY).     0
      THICKNESS   (SHELL ONLY).     0
      PRESSURE    (SOLID ONLY).     0
      VON MISES . . . . . . . .     1
      TURBULENT ENERGY (FLUID).     0
      TURBULENT VISCOSITY(FLUID)    0
      VORTICITY (FLUID) . . . .     0
 VECTOR SAVED ON ANIMATION FILES (1: YES) :
      VELOCITY VECTOR . . . . .     0
      DISPLACEMENT VECTOR . . .     0
      ACCELERATION VECTOR . . .     0
      CONTACT FORCES. . . . . .     0
      INTERNAL FORCES . . . . .     0
      EXTERNAL FORCES . . . . .     0
      SECTION RBY RWALL FORCES.     0
      ROTATIONAL VELOCITY VECTOR    0
      CONTACT PRESSURE (VECTORS)    0
 SHELL TENSOR SAVED ON ANIMATION FILES (1: YES) :
      MEMBRANE STRESS . . . . .     0
      BENDING STRESS(MOMENT/T^2)    0
      UPPER LAYER STRESS. . . .     0
      LOWER LAYER STRESS. . . .     0
      MEMBRANE STRAIN . . . . .     0
      CURVATURE . . . . . . . .     0
      UPPER LAYER STRAIN. . . .     0
      LOWER LAYER STRAIN. . . .     0
 NODAL MASS SAVED ON ANIMATION FILES (1: YES) :    0
 KEEP DELETED ELEMENT (1: YES) :    0
 INITIAL TIME STEP. . . . . . . . . . . . . . . .   0.000000
 MAXIMUM TIME STEP. . . . . . . . . . . . . . . .  0.1000000E+31
 PARALLEL ARITHMETIC ON
 ALE GRID FORMULATION
 NUMBER OF INTERFACES TO BE ELIMINATED. . . . . .        0
 NUMBER OF SOLID  ELEMENT BLOCKS TO BE ELIMINATED        0
 NUMBER OF QUAD   ELEMENT BLOCKS TO BE ELIMINATED        0
 NUMBER OF SHELL  ELEMENT BLOCKS TO BE ELIMINATED        0
 NUMBER OF TRUSS  ELEMENT BLOCKS TO BE ELIMINATED        0
 NUMBER OF BEAM   ELEMENT BLOCKS TO BE ELIMINATED        0
 NUMBER OF SPRING ELEMENT BLOCKS TO BE ELIMINATED        0
 NUMBER OF SH_3N  ELEMENT BLOCKS TO BE ELIMINATED        0
 NUMBER OF  SPH PARTICLES BLOCKS TO BE ELIMINATED        0
 NUMBER OF RIGID LINKS. . . . . . . . . . . . . .        0
 NUMBER OF ALE LINKS. . . . . . . . . . . . . . .        0
 NUMBER OF NEW BOUNDARY CONDITIONS. . . . . . . .        0
 01/06/2015
 CYCLE    TIME      TIME-STEP  ELEMENT          ERROR  I-ENERGY    K-ENERGY T  K-ENERGY R  EXT-WORK MAS.ERR
     0   0.000      0.5044E-06 SOLID        112   0.0%         NaN         NaN         NaN   0.000       0.000
     ANIMATION FILE: universal_jointA001 WRITTEN
  **ERROR : TIME STEP LESS OR EQUAL DTMIN FOR SOLID ELEMENT          91
  **ERROR : TIME STEP LESS OR EQUAL DTMIN FOR SOLID ELEMENT          97
  **ERROR : TIME STEP LESS OR EQUAL DTMIN FOR SOLID ELEMENT         104
  **ERROR : TIME STEP LESS OR EQUAL DTMIN FOR SOLID ELEMENT         105
  **ERROR : TIME STEP LESS OR EQUAL DTMIN FOR SOLID ELEMENT         106
  **ERROR : TIME STEP LESS OR EQUAL DTMIN FOR SOLID ELEMENT         108
  **ERROR : TIME STEP LESS OR EQUAL DTMIN FOR SOLID ELEMENT         111
  **ERROR : TIME STEP LESS OR EQUAL DTMIN FOR SOLID ELEMENT         112
  **ERROR : TIME STEP LESS OR EQUAL DTMIN FOR SOLID ELEMENT         281
  **ERROR : TIME STEP LESS OR EQUAL DTMIN FOR SOLID ELEMENT         282
  **ERROR : TIME STEP LESS OR EQUAL DTMIN FOR SOLID ELEMENT         283
  **ERROR : TIME STEP LESS OR EQUAL DTMIN FOR SOLID ELEMENT         284
  **ERROR : TIME STEP LESS OR EQUAL DTMIN FOR SOLID ELEMENT         286
  **ERROR : TIME STEP LESS OR EQUAL DTMIN FOR SOLID ELEMENT         287
  **ERROR : TIME STEP LESS OR EQUAL DTMIN FOR SOLID ELEMENT         288
  **ERROR : TIME STEP LESS OR EQUAL DTMIN FOR SOLID ELEMENT         289
No idea how to fix it. Thanks in advance.
1 - 5 of 51
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
     Hi,  If you don't use /DT/BRICK... then DTMIN should be 1.E-30, it does not refer to the original time step of this element (look at defaults in the documentation please). On the other hand, if you experience 'TIME STEP LESS OR EQUAL ZERO' it's more likely a fatal error. Unfortunately, when Radioss detects that it is too late for it to output more (usefull information).  Regards  Rahul R
    User: "narasimhamurthy"
    Updated by narasimhamurthy
    Hi,
    i am doing nonlinear geometric analysis in radioss, but error is coming as given in below.
    MESSAGE ID :           79
     ** ERROR : RADIOSS IMPLICIT STOPPED DUE TO TIMESTEP LIMIT **
          ISTOP=-2
         ERROR TERMINATION
    Please suggest me to solve this error.
    Thanks,
    Regard,
    Narasimhamurthy
    Hi,
    Please find attached troubleshooting methods for Istop = 2 error.
    Regards
    Rahul R
    HI,
    Thank you,
    I added the control card PARM,EXPERTNL,YES. Now error is not coming.
    Regards,
    Narasimhamurthy
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    Narasimhamurthy,
    Please always create new topics for your questions,
