Composite Loading
Hi there,
I am trying to run a simulation on the headrest below, however, I keep getting the error
*** See next message about line 28461 from file:
G:/Laura_406_Design/Headrest_V1.fem
(this is continuation line 1 of PCOMP,1 bulk data)
'+ 00.0 0.0 YES'
*** ERROR # 1022 *** in the input data:
Field 2 contains a value outside of allowable range.
I have so far been unable to fix it, despite ensuring the PID is a real integer.
Thank you in advance
Laura
Do you mean I need to enter a thickness under the 'Properties' Section?
Yes, please see the attached image. Thickness and material are missing in the PCOMP card
Thank you for you help before.
I have the model now, and would like to output the deflection of the top of the headrest as a function of the time step. Do you know how to do this/ could you please point me in the right direction?
Cheers
Cheers
Hi @LauraT
If you need the output as a function of time, the input should be a function of time.
Please run a transient analysis for that.
@LauraT
Thickness is not provided on PCOMP for the ply. Please check and try again.
