I'm conducting a steady-state heat convection simulation with Optistruct and wondering if I can see the temperatures after the analysis in a text file?
Import the result file in to HV Select the required results in contour panel Now go to query panel and select required nodes and there contour value Click on Apply and export it as .csv file.
