*** ERROR # 1000 *** in the input data: Incorrect data in field # 3
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi I am new to this software and I received this message after running optistruct analysis and I dont understand what I did wrong?
Thanks, Neek
 Incorrect data in field # 3.
 There were 4200 error messages during input processing.
  The first message is repeated below:
  *** See next message about line 3516 from file:
      C:/Users/neel_/Desktop/Dissertation/3dmodel.fem
   'CQUAD4      1430       0      42      59    2059      43'
 ==== End of solver screen output ====
 ==== Job completed ====
31 - 53 of 532
    Altair Employee
    OP
    I don't have all the material properties to fill in the properties on the MAT9ORT or Mat9 card so i chose to do MAT8 car instead, should i just assume that the values in 1-2 direction is equal?
    Thanks, Neel
    Altair Employee
    OP
    @neelc14
    I think MAT9ORT is straight forward. You can use the MAT8 parameters as it is in MAT9ORT.
    Altair Employee
    OP
    Hi I changed the material o MAT9ORT and i receive this error I don't understand what I am doing wrong?
    Messages for the job:
     *** See next message about line 22774 from file:
         C:/Users/neel_/OneDrive/Documents/Dissertation/2d model/honeycomb/alhoneycomb3d.fem
      'CQUAD4     16667       0      39   21725     228      40'
     Too many error messages. Aborting run.
     Current limit is 10000. Use 'MSGLMT' control card to change this value.
    Neel
    Altair Employee
    OP
    Hi @neelc14
    Use MaT9ORT only for solid elements. Looks like you changed material and properties for all elements.
    Altair Employee
    OP
    Hi, I only changed the card image for aluminium honeycomb to mat9ort and nothing else but it seems to come up with that error still?
    I have attached the file for reference.
    Neel
    Altair Employee
    OP
    Hi Neel,
    For core you have PSHELL property which is not compatible with solid elements.
    Change PSHELL to PSOLID property for core component.
    Altair Employee
    OP
    Hi Prayesh,
    Sorry but I already tried that and got an error message again after I ran optistruct analysis.
    Neel
    Altair Employee
    OP
    Neel,
    Try this attached .fem file.
    Some of the elements did not had a valid property. I updated the model.
    Altair Employee
    OP
    Hi Prayesh could you send me the model file as well please if possible?
    Neel
    Altair Employee
    OP
    Hi Prayesh,
    I imported the FEM file into Hyperworks and I still receive an error when I try to do Optistruct analysis.
     *** See next message about line 23157 from file:
         C:/Users/neel_/OneDrive/Documents/Dissertation/2d model/honeycomb/alhoneycom3d.fem
    Neel
    Altair Employee
    OP
    Hi Neelc14,
    Same file runs for me without any errors.
    Can you try this .hm file?
    Altair Employee
    OP
    Hi, when i try to open the file it says that this file is a 17.01-0 file is not backwardly compatible and nothing comes up. I have the student version v14.0 of Hyperworks is there some way you could change the version so that I can view it?
    Thanks, Neel
    Altair Employee
    OP
    @neelc14
    Try this file. Saved from 14.0.
    Also, update the Dof on one side of the model. Y is free which deforms the part to a larger extent.
    Altair Employee
    OP
    What should I update it to? Because in a three point bending machine there is a roller support at one end meaning that the dof2 is free and cannot be constrained?
    Altair Employee
    OP
    Neel,
    The model is not constrained in the direction of load. Check this and update accordingly :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
    Altair Employee
    OP
    Hi Prakash,
    Sorry one more question i want to change the mesh element size after the model has been created from 3mm to 5mm how would I do that? Because when i do 2d>automesh and select the model and change the size from there an error comes up? What is the easiest way to do this?
    Thanks, Neel
    Altair Employee
    OP
    Neel,
    Can you post the error message, please?
    To Remesh Shell elements, what you are following is correct. Also try to disconnect nodes between components before you remesh.
    Altair Employee
    OP
    Hi,
     *** See next message about line 64 from file:
         C:/Users/neel_/OneDrive/Documents/Dissertation/2d model/2dmodel.fem
      'SET     1       ELEM    LIST'
     *** ERROR # 1728 *** in the input data:
     Incorrect SET definition.
    I receive this message. How would I be able to disconnect nodes between components?
    Neel
    Altair Employee
    OP
    Neel,
    Looks like you have a set with elements, you remeshed those elements and the set has old element IDs.
    You need to create another element set.
    In order to detach elements, go to 2D page>> Detach is the option
    Altair Employee
    OP
    Hey sorry,
    But i receive very large values when I run the optistruct analysis? I dont understand what the problem is, the picture below helps to show the displacement.
    Thanks, Neel
    Altair Employee
    OP
    The values I should obtain should be much smaller than this around 5mm or so.
    Altair Employee
    OP
    Hi neelc14,
    Check the constraints. I think you have an unconstrained model.
    Best regards,
    Gonçalo
    Altair Employee
    OP
    @neelc14
    It  could be not constrained or under constrained.As @GonPer suggested check the constrains.
31 - 53 of 532
