🎉Community Raffle - Win $25
Join and Win
Connect Weld to Body Failed?
User: "Brian_20847"
Altair Community Member
Updated by Brian_20847
Hi everyone,
I am following static analysis of welded knuckle in learning center. When I connect weld to body, it inform that update hex mesh failed.
Thanks.
1 - 4 of 41
    User: "Santhoshkumar"
    Altair Employee
    Updated by Santhoshkumar
    Hello Brian,
    Could you please select the adjacent face also from the cylinder body as shown below and try the connect weld?
    Thanks & Regards,
    Santhoshkumar
    User: "Brian_20847"
    OP
    Hi Santhoshkumar,
    Thanks for your help.
    Can you share me csv file about elasto-plastic material for this tutorial: Non Linear Analysis with Friction and Material.
    Best regards.
    Altair Employee
    Hi Santhoshkumar,
    Best regards.
    Hello Brian,
    Please find the attached CSV file for elastic-plastic material.
    Note: Rename B730_stress_strain.txt to B730_stress_strain.csv
    Thanks & Regards,
    Santhoshkumar
    User: "Brian_20847"
    OP
    Accepted Answer
    Hello Brian,
    Thanks & Regards,
    Santhoshkumar
    Hi Santhoshkumar,
