Hi everyone,
I am following static analysis of welded knuckle in learning center. When I connect weld to body, it inform that update hex mesh failed.
Thanks.
Hello Brian, Please find the attached CSV file for elastic-plastic material. Note: Rename B730_stress_strain.txt to B730_stress_strain.csv Thanks & Regards, Santhoshkumar
Hello Brian,
Thanks & Regards,
Santhoshkumar
Hi Santhoshkumar,
Thanks for your help.
Could you please select the adjacent face also from the cylinder body as shown below and try the connect weld?
Can you share me csv file about elasto-plastic material for this tutorial: Non Linear Analysis with Friction and Material.
Best regards.
Hi Santhoshkumar, Thanks for your help. Can you share me csv file about elasto-plastic material for this tutorial: Non Linear Analysis with Friction and Material. Best regards.
