Altair RISE
Nominate Yourself Now!
Error while validating the design in CMA
User: "Ahmed El Yousfi"
Altair Community Member
Updated by Ahmed El Yousfi
Hello,
I am trying to simulate a slot antenna in an infinite ground plane through characteristic mode analysis in FeKO. The design contains a slot plus infinite ground and a port feed (voltage source), when I checked the design using CEM validate it shows the following error "Only MoM solution methods are supported in Characteristic modes". The thing I can not understand is although there is an error the simulation is finished and shows results.
Attached is my design.
Any help will be highly appreciated.
Thanks
1 - 1 of 11
    User: "Mel"
    Altair Employee
    Updated by Mel
    This is a known issue which will be fixed. Indeed you can ignore this message.
