🎉Community Raffle - Win $25
Join and Win
Error while validating the design in CMA
User: "Ahmed El Yousfi"
Altair Community Member
Updated by Ahmed El Yousfi
I am trying to simulate a slot antenna in an infinite ground plane through characteristic mode analysis in FeKO. The design contains a slot plus infinite ground and a port feed (voltage source), when I checked the design using CEM validate it shows the following error "Only MoM solution methods are supported in Characteristic modes". The thing I can not understand is although there is an error the simulation is finished and shows results.
Attached is my design.
Any help will be highly appreciated.
Thanks
