🎉Community Raffle - Win $25
Join and Win
Error: Check OptiStruct input file
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi!
I received the following error message in SimLab when I tried to solve a Normal Mode problem with the solver OptiStruct:
Error: Check OptiStruct input file.
I have followed a tutorial, so I do not think there is something wrong with the boundary conditions, and when I tried the same thing a few days ago it did work. (I have tried different set ups as well, but receives the same error message).
Do you know what could be wrong/what can I do to search for the problem?
1 - 5 of 51
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    which version of simlab you are using?Also could you share out file of the run?
    Regards
    Rahul R
    Altair Employee
    OP
    I am using version 14.0.
    Altair Employee
    OP
    I receives the same error message in the output files for every file/set up I have tried, for both solving the analysis and for optimization.
     A fatal error has been detected during input processing:
      *** See next message about line 5 from file:
          C:...
       (this is continuation line 1 of OUTPUT data
       'SCREEN NONE'
      *** ERROR # 1004 *** in the input data:
      Orphaned continuation data (previous card had a trailing comma).
    Altair Employee
    OP
          C:...
       'SCREEN NONE'
    Altair Employee
    OP
    Hi,
    Can you open the .fem file in text editor and Search for the word SCREEN and change it to SCREEN, OUT
