P13-SPR-beam of tension, shear, beding
tuan trinh
tuan trinh Altair Community Member
edited June 2021 in Community Q&A
I  have a question about it, please help me
is it really necessary to crate tension, shear, beding?
If necessary, which is necessay in all (K, C, A, D, function…)
How to decide value of K,A,..
2>function  -ID-tension
How to decide value of Function graph?
if part material is alimuni, rubber and fe
Answers
  • Rogerio Nakano_21179
    Rogerio Nakano_21179 New Altair Community Member
    edited June 2021
    Hi
    If you need the element to behave properly , the stiffnesses associated to the degree of freedom need to be defined.
    You can start by defining then as elastic, only stiffness , and after enrich the information.
    I hope this is helpful
    Regards
Welcome!
Welcome!
