Altair RISE
Nominate Yourself Now!
How to Export Node set ID/Name in HyperView While Exporting Query Stress/Displacement Results
User: "srinivas rallabandi_21059"
Altair Community Member
Updated by srinivas rallabandi_21059
I am trying to Export stress results using the Query Option in Hyperview as a *.CSV/*.txt file.
I am using Node By set option to export my results. How to include Setname/Set ID in the CSV File.
Any script is available to include the Set ID/name
Here is the attached Image which I am looking for as a reference
1 - 10 of 101
    User: "Nagahashi Kouta"
    Updated by Nagahashi Kouta
    Hi, srinivas rallabandi
    May I know the result file type in your question ?
    If you are using optistruct, You can achieve this by writing scripts.
    OP
    Hi Nagahashi
    I am using Nastran as the solver and my final result file is in OP2 format
    Sorry for replying late. When you create a set of nodes in HyperView, you can export the set info using a text file in TXT format.
    After you export the results obtained by Query, you can use a TCL script or Python script to match the information of the two files, and write the set name corresponding to the node id into the text file obtained by query.
    OP
    I tried to Export my Node Sets using the Export Option and Tried both Formats
    1)- Hyperview Format
    2) Nastran-Format
    Do you Recommend any basic command ( Python or SED, AWK)  to start or Compare both of them
    Thank you
    Are you familiar with Python?
    Use Python to read the set information file and exported query result file respectively, and match them according to the node ID.
    This seems feasible.
    OP
    Thank you So much Nagahashi, Let me give a try
    OP
    I tried with awk and sed bash script unfortunately it was taking either column or CSV format as my file format in the file-1.txt  is different than file-2.txt. As you see here it has to find a match on file-2.txt based on file-1.txt and assign value (SET N) to the file-2.txt.
    Unfortunately, there is no common field/column between these two files  :(
    File-<span class="hljs-number">1.</span>txt ---------- SET <span class="hljs-number">6</span> = <span class="hljs-number">11032</span>,<span class="hljs-number">13639</span>,<span class="hljs-number">13984</span>,<span class="hljs-number">13992</span> SET <span class="hljs-number">7</span> = <span class="hljs-number">14000</span>,<span class="hljs-number">14008</span>,<span class="hljs-number">14016</span>  File-<span class="hljs-number">2.</span>txt ---------- <span class="hljs-number">11032</span>, <span class="hljs-number">2.820E+02</span> <span class="hljs-number">13639</span>, <span class="hljs-number">2.490E+02</span> <span class="hljs-number">13984</span>, <span class="hljs-number">3.056E+02</span> <span class="hljs-number">13992</span>, <span class="hljs-number">3.172E+02</span> <span class="hljs-number">14000</span>, <span class="hljs-number">3.106E+02</span> <span class="hljs-number">14008</span>, <span class="hljs-number">2.819E+02</span> <span class="hljs-number">14016</span>, <span class="hljs-number">2.380E+02</span>  Desired Output -------------- SET <span class="hljs-number">6</span>,<span class="hljs-number">11032</span>, <span class="hljs-number">2.820E+02</span> SET <span class="hljs-number">6</span>,<span class="hljs-number">13639</span>, <span class="hljs-number">2.490E+02</span> SET <span class="hljs-number">6</span>,<span class="hljs-number">13984</span>, <span class="hljs-number">3.056E+02</span> SET <span class="hljs-number">6</span>,<span class="hljs-number">13992</span>, <span class="hljs-number">3.172E+02</span> SET <span class="hljs-number">7</span>,<span class="hljs-number">14000</span>, <span class="hljs-number">3.106E+02</span> SET <span class="hljs-number">7</span>,<span class="hljs-number">14008</span>, <span class="hljs-number">2.819E+02</span> SET <span class="hljs-number">7</span>,<span class="hljs-number">14016</span>, <span class="hljs-number">2.380E+02</span>
    Sorry, I'm not familiar with awk and sed bash scripts.
    It's easy to do this with python or tcl/tk scripts.
    OP
    what is the function you are using in Python for this
    OP
    I tried  half by reading my second file (File-2.txt)  as a dictionary
    from openpyxl import load_workbook
    wb = load_workbook("file-2.xlsx")
    sheet1 = wb.worksheets[0]
    list_dict=[]
    dict={}
    for row_value in range(1,sheet1.max_row+1):
    dict.update({sheet1.cell(row=7,column=1).value:sheet1.cell(row=row_value, column=2).value})
    list_dict.append(dict)
    print(list_dict)
    Now I need  read file-1.txt , and create the output file by looking up the values in the dictionary
