4y no answer ?!
Batch HW
https://2021.help.altair.com/2021/hwdesktop/altair_help/topics/tools/hvvh_batch_mode_r.htm
http://www.hyperproc.com/hwhelp/2020/topics/reference/hwdref/batch_mode_run_hw_t.htm
a batch file that is usefull if You still change FEM files in notepad
:: BAT FILE THAT CAN BE USED TO CALL FEM SOLVER
@ECHO OFF
:: Define proper paths
set Path=%Path%;C:\Program Files\Altair\2021\hwsolvers\optistruct\bin\win64;C:\Program Files\Altair\2021\hwsolvers\common\bin\win64;C:\Program Files\Altair\2021\hwdesktop\hw\bin\win64\
set filename=%1
:: define proper solver
optistruct_2021_win64 -help
optistruct_2021_win64 %filename% -analysis
:: POSTPROCESS
for %%f in ("%filename%") do set filename=%%~nf
set outfile=%filename%.out
set spcfile=%filename%.force
type %outfile%
type %spcfile%
:: USER QUESTION FOR RUNNING HyperView
:choice
set /P c=Do You Want open the HW [Y/N]?
if /I "%c%" EQU "Y" goto :some_label
if /I "%c%" EQU "N" goto :some_else_label
REM else repeat question
goto :choice
:some_label
::"C:\Program Files\Altair\2021\hwdesktop\hw\bin\win64\hw.exe"
hw.exe %filename%.h3d
:some_else_label
echo "I am here because you typed Y"
pause
exit
Hi Mayur,
I will check and update you soon.
