🎉Community Raffle - Win $25
Join and Win
Hyperstudy to Fluxmotor
User: "Ali Sawan"
Altair Community Member
Updated by unknown
I made an Optimization study and i want to show the result on Fluxmotor Catalog , i thought it happens automatic but it´s not working ,on Fluxmotor there wasn´t any new Catalogs showing.
How is it possiple to deffine the output responses or How can i add the result as new Catalo on Fluxmotor?
I would approciate some help .imageimage
1 - 4 of 41
    User: "Jaime Maraví"
    New Altair Community Member
    Updated by Jaime Maraví
    Before exporting the Flux Motor file to Hyperstudy, you need to click on "Save iterations" on Flux Motor. It then creates a new catalog with the all the iterations.
    Hope that helps.
    Jaime
    User: "Diana_38240"
    Altair Employee
    Updated by Diana_38240
    Hello,
    Thank you both for the question and the answer.
    I'd like to comment on it hoping it will be helpful for you and other users.
    Actually, there are two possibilities (one can use one or another, or both).
    1) If you want to look at the tested designs in the FluxMotor catalog (open it outside HyperStudy), you would need to set "Yes" on Save iterations when exporting the component. Then every tested designs will be available in the catalog for review.
    2) Or you can use Media to get the previews of the tested designs directly in HyperStudy without saving the catalog (no need to set "Yes" on Save iterations).
    In other words, Media is an alternative solution to the catalog, which is available directly in HyperStudy.
    Please look at the video in the blog below. Between 6:00 to 8:13 there is a concrete example with FluxMotor which I think will be useful to understand how it works.
    HyperStudy 2022.0 New Features and Enhancements
    https://community.altair.com/community?id=community_blog&sys_id=51587c651ba68d50c4dfdbd9dc4bcbfc
    Now, back to the the initial question. If you want to use Media in HyperStudy (without saving the iterations in a FluxMotor catalog) you can do so. I think that it didn't happen on your side because you need to define the media source(s) first (if you pay attention on the second image you shared it is written "No media defined"). As shown in the video above you just need to go in Define Output Responses, Media and select the image (png) provided by FluxMotor. Then when you run a DOE or Optimization the images for each run will be available for review.
    For information, I'm sharing two other blogs which can be of interest for you
    HyperStudy Tips and Tricks: #16 – Know More about the HyperStudy-FluxMotor Connection
    https://community.altair.com/community?id=community_blog&sys_id=8253756ddbb45910cfd5f6a4e2961980
    HyperStudy Tips and Tricks: #15 – Top 5 Guide of the HyperStudy-FluxMotor User
    https://community.altair.com/community?id=community_blog&sys_id=f3e9a121dbb45910cfd5f6a4e296192f
    Does this help?
    Regards,
    Diana
    User: "Melih Ayyildiz_22506"
    Updated by Melih Ayyildiz_22506
    Hello,
    Does this help?
    Regards,
    Diana
    Hey Diana,
    quick question regarding your second tip: Is it possible to extract the media files after a DOE run? I saved the iterations within the HyperStudy catalog in FluxMotor but unfortunately didn't search for the media files in the media tab before the DOE run. Is there a way to reimport them after the DOE run?
    User: "Diana_38240"
    Altair Employee
    Hey Diana,
    Hi Melih,
    Yes, You can bring the images after your DOE has been solved. For this you would need to enable the images of interest in Output Responses - Media sources tab:
    And then use the "Media" tab in Postprocessing.
    Please note that that "Save Iterations in FluxMotor Catalog" and Media are two different capabilities. You can import the png in HyperStudy even though you didn't click Yes to Save Iterations when creating the HstConnector. Does that make sense?
    Hope it helps.
    Diana
