🎉Community Raffle - Win $25
Join and Win
Errors in Radioss
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I am getting errors in RADIOSS when I tried to simulate the crash model that has been exported from HyperCrash.
ERROR ID :          286
** ERROR IN INPUT CONSISTENCY
DESCRIPTION :
   QUAD ARE NOT COMPATIBLE WITH N2D3D=0
ERROR ID :          760
** RADIOSS STOP DUE TO INPUT ERROR
What would be the solution for these errors?
I cannot share the model due to the confidential issues.
1 - 9 of 91
    User: "Pranav Hari"
    Altair Community Member
    Updated by Pranav Hari
    Hi j8jang
    Due to wrongly assigned property cards to components, RADIOSS throws this error. Please check and ensure whether the components are assigned with the correct property cards.
    Assign PART card image to components and NONE to rigids.
    Also, try the below suggestion and check if you still get error ID 286:
    Goto 2D page>> ELEMTYPES>> make sure for 2D and 3D are as shown in the below image. If not change the tria3=SHELL3N and quad4=SHELL4N.
    Altair Employee
    OP
    Hi Pranav,
    For error ID: 760, it was discovered that the dummy model we have imported caused an error so we have simply removed it for now.
    However, for the error ID 286, we already had the element type set up to the shown image.
    I have included the photo of error checks. I am able to auto-fix/manually fix everything except for '0 or 1 Slavenodes in Rbody' error which we already have set up and 'Part and Subset cards' error which I am not sure why it makes an error.
    Can you please let me know why you think it is causing the error and how we can fix this?
    Thank you.
    Brian
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi,
    there are  QUAD4N elements in your model which are incompatible with 3D analysis type.
    In the 2D>elem type panel the element type settings are only valid for newly created elements. You should select QUAD4N elements (elems>by config>config:quad4 type:QUAD4N) and update to change element type of existing elements. This will probably also resolve the Compatibility: Part/Mat/Prop error.
    Altair Employee
    OP
    Hi,
    We have changed the QUAD4N elements and updated the changes. But we get this error.
    Again, I think we are able to fix all these errors. We just have to set new BC, Accelero card and node cards for the replaced parts.
    But we still get 'Part and Subset Cards' and 'Rigid Body Cards' errors.
    Please let me know other possible methods that can get rid of these errors
    Thanks
    Can you share the model?
    Altair Employee
    OP
    I'm sorry, due to the confidential issue, we are not able to share the model.
    Is there another way instead of releasing the model? (maybe via real-time chat or phone call?)
    That's OK, I understand. Let's first try to resolve those issues here.
    Looks like component 'QUAD' has more than one element type. Try running the model and review the starter out file (runname_0000.out). Find the errors where offending element ID will also be listed. You can also review the elements in 2D>elem type panel and search the starter input deck (runname_0000.rad) with different element type keywords (QUAD, SHELL,...).
    'Rigid Body Cards' error is not unusual and it will not prevent the model from running.
    Altair Employee
    OP
    After resetting the mesh element type and fixing the rest of the errors, we were finally able to get rid of all the errors from the model check in hypercrash.
    However, when we ran the model on Radioss, the same errors keep popping up.
    Can you please tell us why?
    Another question is that we tried to import the model on hyperview to see if the simulation animation works, but it says datatypes are not available in provided files.
    The last possibility I can think of why QUAD elements are still present in your model is they are automatically regenerated by TCL script.
    I haven't yet faced this Hyperview issue. Looks like you have loaded a model without appropriate datatypes for the chosen Result-Math template.
    Refer to the tutorial:
    HMath-5000: Using HyperMath in HyperView Results Math
