Regenerative Braking for DC Motor
Hi Everyone
I have a question about simulation in PSIM.
can it simulate regenerative braking on a DC motor in PSIM?
Thank you
best regard
-fatur
Hi Fathur,
The PSIM model can handle regenerative braking on a DC motor as all the models are 4 quadrant.
Regards
Amit
Hi Gary
Thank's for the replay and suggestion. I will try it.
Best Regard
Fatur
Hi Amit
Best Regard
Fatur
Hi…I normally hear that regen gives about a 10% expansion in range, clearly that will fluctuate with city/interstate driving yet 10% is the number that is constantly tossed around. Furthermore, I believe that the prius regen returned about 30%, so you would get 60A back. These aren't strong numbers from studies or anything, exactly what the vast majority say when talking regen
just my 2 cents, I guess the simplest model for DC motor is iLdi/dt + R*i + backemf.
L & R do not change from motor accelerates till decelerates. The bemf.
you may model the bemf voltage according to the speed profile of the motor.
During deceleration, the bemf pumps back current to your cap bank at the DC link.
The DC motor circuit in this link below might help.
