Altair RISE
Nominate Yourself Now!
Penetration Tool as in HW14.0
User: "Udhayakumar Ramasamy"
Altair Community Member
Updated by Udhayakumar Ramasamy
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.598928601e59549403ccfa305178fdf1.png
Above mentioned pages will come in HW14.0 but HW2017 penetration in LSdyna is coming as below. How to change this? or how Can I enable same settings in HW2017.
I checked each and every option in HW2017, but results are not same as HW 14.0
1 - 16 of 161
    User: "tinh"
    Updated by tinh
    Hi,
    which option would you like?
    I see thickness option is 'component thickness' which is same as in v14
    v2017 can check it base on contact so I think it's better
    It just hides the original panel. If you still want to use it, try enter commands (in menu View>Command Window):
    hm_setpanelproc hm_resetmenu
    hm_pushpanel penetration
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi,
    You can use the traditional way by going to Tool Page>> Penetration panel
    OP
    But that is not available in HW2017.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.bcf971da27c0ca81eb8254ccda7dca16.png
    I searched in buildup menu also. But it is not there.<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.80dab06973b319d05a81eed95c8a9dee.png
    OP
    Hi tinh,
    Thanks for your reply. But it says following error.
    Actually 14.0 is very helpful for checking initial penetrations
    Altair Employee
    Hi Udhay,
    Select the Penetration Check tool from the Tools Menu.
    OP
    Yeah George. It is there. But it is not traditional way. Same components i check in 14 and 2017 showing different results. This is happening in LS dyna profile.
    2017
    14.0
    Altair Employee
    Hi Udhay,
    I'm not sure, there might be some modifications in the latest penetration check tool.
    Can you try the same in HyperCrash?.
    User: "tinh"
    Updated by tinh
    Hi tinh,
    <?xml version="1.0" encoding="UTF-8"?>image.png.7e9f4ad8f563df3ca719389716febbb3.png
    Hi,
    I said above, you need to enter 2 commands:
    OP
    Yeah tinh...
    Thanks for your help..
    It worked in Hyperworks2017
    George,
    I am not well versed in hypercrash... Sorry
    User: "tinh"
    Updated by tinh
    Yes, but I advise you to use new style and check with 'contact'
    traditional style cannot check all penetrations for lsdyna model, this problem I faced from 2007, and until 2017 they just attach the checking method by contact, you should use it.
    OP
    Yeah tinh...
    Thanks for your advise. I am checking that also but  using Lsdyna d3hsp file.  I will try to use this from now onwards.
     Once again thanks.
    User: "tinh"
    Updated by tinh
    Yeah tinh...
     Once again thanks.
    I had a macro to parse d3hsp and mark penetrated nodes by depth value
    OP
    Oh great.. if you are okay. share the details with me....
    User: "tinh"
    Updated by tinh
    Hi,
    script like this
    proc p_ParseD3hsp {FilePath} {
        if {[file exists $FilePath]} {
            if {[catch {
                set fpt [open $FilePath]
                set buffer [read -nonewline $fpt]
                close $fpt
                return -code error $::errorInfo
            set LineList [split $buffer \n]
            array set PenValue {}
            set MismatchedModel 0
            foreach Line $LineList {
                set Line [string trim $Line]
                switch -glob -- $Line {
                    'penetrating node # *=*' {
                        set NodeId [string trim [string range $Line 28 end]]
                        if {![hm_entityinfo exist nodes $NodeId]} {
                            set MismatchedModel 1
                            break
                    'penetration *=*' {
                        set PenValue($NodeId) [string trim [string range $Line 28 end]]
                        catch {
                            *tagcreate nodes $NodeId [format %.2f $PenValue($NodeId)] $NodeId 2
            if {$MismatchedModel} {
                return -code error 'The d3hsp mismatched with opening model'
            #return [array get PenValue]
        } else {
            return -code error 'File not existing '$FilePath''
    OP
    Thanks a lot tinh... I will check this....:)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    User: "rohit123"
    New Altair Community Member
    Updated by rohit123
    hiii...explain again
