🎉Community Raffle - Win $25
Join and Win
Failed to import CAD into Simlab?
User: "James Lewis"
Altair Community Member
Updated by James Lewis
Hi guys,
I try to import parasolid CAD file into SimLab, but it failed.
The dialog showed as below.
Anyone what problem happened.
Best regards,
James
1 - 2 of 21
    User: "Aniruddha Duggani"
    Altair Employee
    Accepted Answer
    Updated by Aniruddha Duggani
    Hi James Lewis,
    Probably the Parasolid file you have might contain a sheet part.
    In the default import options when you import a Parasolid file, you will see that sheet is not selected.
    Please mark the sheet option and then try import the file.
    This might solve the challenge you're facing.
    Thanks
    Aniruddh
    User: "James Lewis"
    OP
    Hi James Lewis,
    Thanks
    Aniruddh
    Hi Aniruddha,
    Thank you for your quick response.
    My part do not contain any sheet parts.
    And I found that my problem is not creating environment variables for license file.
    I've created an environment variables for license file and import function worked.
    Before, I've just pasted license file in security folder.
    Best regards,
    James
