🎉Community Raffle - Win $25
Join and Win
Bird strike example
Hello, I am doing this example https://altairuniversity.com/26447-bird-strike-analysis-on-an-aircraft-leading-edge-using-sph-bird-model/
However, I am stuck on the following step:
The loads and boundary conditions for the model are created now. From Utility Menu, select BCs Manager. Provide a name for the load collector and select type as Boundary Condition. From the selector choose nodes and select the master node of the rigid body created. Fix all the degrees of freedom and click create
I am using 2021.2 and I can not find this? One additional question: why in every release things are moved around? It is a little frustrating. Also, the option to find some pannels is not working that good. Thank you.
1 - 3 of 31
