🎉Community Raffle - Win $25
Join and Win
[optistruct] FATAL ERROR # 9171 32-bit overflow in memory allocation for "lgnnl"
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello everyone,
I've encounter an error while using the optistruct solver. It says:
Errors reported during program execution
Error output from the solver:
 *** WARNING: The amount of allocated memory exceeds available RAM - this
may cause significant slowing down of solution progress due to the swapping
out memory to the swap file. It is recommended to use out-of-core
solution to reduce memory requirements.
hwsolver.mesg output from the solver:
 *** FATAL ERROR # 9171 ***
 32-bit overflow in memory allocation for 'lgnnl'.
It's very strange that the system didn't report 'not enough memory'. Rather, from the task manager memory window, I observed a steep increase in memory usage up to my max memory (32GB) and then the solver instantly failed.The fem file is quite large, about 3.7GB. I also forced out of core solution. The free disk space is about 600GB. It's a RAID 0 ssd setup btw. Can anyone plz help me on this issue?
Cheers,
Edward
