Optistruct Static analysis is taking long time to solve
Hi All,
Please help me out for solving OptiStruct linear static analysis.
Problem: Since from 35hours solver is running but no result.
Already written 520GB size scratch file, till increasing. Taking all 32GB ram and 8 core. I have HW 50 tokens.
Out file is:
FINITE ELEMENT MODEL DATA INFORMATION :
Total # of Grids (Structural) : 1654487
Total # of Elements Excluding Contact: 1173042
Total # of N2S Contact Elements : 434140 (internally created CGAPG)
Total # of Rigid Elements : 222519
Total # of Rigid Element Constraints : 2059857
Total # of Local Coordinate Systems : 1
Total # of Degrees of Freedom : 9926916
Total # of Non-zero Stiffness Terms : 267537486
Element Type Information
CONM2 Elements : 51
CQUAD4 Elements : 1169800
CTRIA3 Elements : 3191
Load and Boundary Information
FORCE Sets : 1
SPC Sets : 1
Material and Property Information
PSHELL Cards : 16
MAT1 Cards : 1
OPTIMIZATION PROBLEM PARAMETERS :
NO DESIGN MATERIAL OR DESIGN VARIABLES FOUND : ANALYSIS ONLY
Static Subcase Summary :
Subcase ID SPC ID FORCE ID
1 4 3
Run Type : Analysis Only
Scratch file directory : ./
Free space: 740.308 GB
Number of CPU processors : 8
MEMORY ESTIMATION INFORMATION :
Solver Type is: Sparse-Matrix Solver
Direct Method
Current Memory (RAM) : 5484 MB
In addition a ramdisk area was allocated in memory : 200 MB
Estimated Minimum Memory (RAM) for Minimum Core Solution: 5251 MB
Recommended Memory (RAM) for Minimum Core Solution : 5251 MB
Estimated Minimum Memory (RAM) for Out of Core Solution : 8782 MB
Recommended Memory (RAM) for Out of Core Solution : 9785 MB
Recommended Memory (RAM) for In-Core Solution : 58386 MB
(Note: Minimum Core Solution Process is Activated.)
(Note: The Minimum Memory Requirement is limited by Assembly Module.)
(Note: Use param,HASHASSM,yes to avoid assembly module memory bottleneck)
DISK SPACE ESTIMATION INFORMATION :
Estimated Disk Space for Output Data Files : 648 MB
Estimated Scratch Disk Space for In-Core Solution : 9103 MB
Estimated Scratch Disk Space for Out of Core Solution : 74786 MB
Estimated Scratch Disk Space for Minimum Core Solution : 79320 MB
BEGINNING ANALYSIS SOLUTION ....
ANALYSIS RESULTS :
ITERATION 0
System Config:
** Windows 7 Workstation SP1 (Build 7601) DELL01-PC **
** 8 CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz **
** CPU speed 3400 MHz **
** 28696 MB RAM, 65418 MB swap **
Please help me whether I have to wait for run. if yes please suggest me approximate time it may take.
Thanks and Regards,
Shriram S Kalburgi
Thank you Q.NGUYEN-DAI,
I will check the possibility.
Is there any other option, so that I can solve my problem.?
Thank you.
Hi Shriram,
One of our Support Engineers from INDIA will get in touch with you soon.
