Altair RISE
Nominate Yourself Now!
Problems to create solid
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I've got a problem with solid creating for mesh. When i try to do this  'no closed volume found' message displays.
There's no free edges so i don't know where is the problem.
I import geometry from STEP file:
Then go to geometry solid -> bounding surfaces
<?xml version="1.0" encoding="UTF-8"?>post-40403-0-96291500-1444495798_thumb.j
<?xml version="1.0" encoding="UTF-8"?>post-40403-0-87031000-1444495999_thumb.j
1 - 15 of 151
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi
    - isolate only the component
    - switch to topology color
    - click on visualization button
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-89637100-1444618323_thumb.pn
    - uncheck shared, suppressed, t-connection
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-85109500-1444618324_thumb.pn
    looking for remain free edges of surface and fix it (F11 > toggle, or filler surf
    Altair Employee
    OP
    Sorry I haven't got any of free edges (red) all of them are green
    Here is link to stp (STEP) file.
    http://www.speedyshare.com/gtP9V/T4-1704-0000080-AB.stp
    User: "Merula_20758"
    Updated by Merula_20758
    Hi,
    could it be that the solid is already there image/emoticons/default_wink.png' alt=';)' srcset='/emoticons/wink@2x.png 2x' width='20' height='20'> ?
    As I imported the step file and masked every solid displayed, there is no geometry left.
    Best regards,
    Merula
    Altair Employee
    OP
    Imported into my HM13, I got ... all solids image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    So where's your problem?
    Altair Employee
    OP
    But when I try to do solid map mesh of my model some of errors displays  'At 0/38. Solid 17: Non-mappable(2): along-faces from 1 loops, need 2'
    <?xml version="1.0" encoding="UTF-8"?>post-40403-0-24327000-1444671460_thumb.j
    You want to mesh all solids with solid map? The problem is, that those solids do not share surfaces... Maybe rebuild/rethink the geometry.
    Altair Employee
    OP
    Hey, 'solid map' meshing is ... not a 'cheap' method to work :-)
    In order to make them 'mappable' you have to ... work and work a lot, not just ONE click image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    Have a look at Hypermesh manual & tutorials please !!!
    Altair Employee
    OP
    Yea I've already reached it by auto-contact tool, thank you for your help and suggestions.
    Do you know how can i repair my model ? Can i use HyperWorks to do this ?
    I watched some tutorials and there was no similar problem solved there,
    Please upload the .hm file where your error occurs, then we can have a look.
    best regards,
    Merula
    User: "tinh"
    Updated by tinh
    Yes, I agree.
    one thing to remeber when meshing a hex/penta part: do it from the most complex portion to simplest one
    Altair Employee
    OP
    To add to the above, make as much mappable as you can.
    This makes it easy to mesh.
    Altair Employee
    OP
    Why i can't merge these solids ? Should I do this in another way ? How to make the solids to share surfaces ?
    There's no tutorial about this problem :/
    Altair Employee
    OP
    Geom => Solid edit => merge
    Altair Employee
    OP
    Yea I know that but it's not working.
    User: "tinh"
    Updated by tinh
    Yes, sometimes solid merge do not work
    instead of merging you can create big solid by selecting bounding surfaces
    HM is not ideal for CAD processing, so some geometry functions not work in some case. but you will always find a workaround
