Altair RISE
Nominate Yourself Now!
*** ERROR # 1000 *** in the input data: Incorrect data in field # 7.
User: "Jacob McNutt"
Altair Community Member
Updated by Jacob McNutt
This line was interpreted as:
2727236:RBE3, 17114232, , 15008653, 123456, 0.945518, 0, 15521090, 0.0444824
Expected COMPONENT numbers, found INTEGER (0)
How do I fix this error? It appears for almost all of the RBE3 elements. I had to place my model into an Abaqus model from my customer to run a analysis and this is the error that I receive.
1 - 2 of 21
    User: "Adriano Koga_20259"
    New Altair Community Member
    Updated by Adriano Koga_20259
    Hi,
    I would suggest you to read this post for understaing better the meaning of error #1000.
    https://community.altair.com/community?id=community_question&sys_id=3c76043a1b2bd0908017dc61ec4bcbed&view_source=searchResult
    From your .out file:
     *** See next message about line 2727230 from file:
         D:/HyperWorks Simulation/RIVIAN/Rivian_IP_CCB_STUDY/ASSY-CROSS CAR BEAMRPV-700900LHD A.1/REV46_ASM_MESH_SIZE_OF2/bedplate_test-12_1-piece_grab_tube/remove ps plenum/biw/ASSY-CROSS CAR BEAMRPV-700900LHD A.1_biw_test.fem
      "RBE3    17114229        15008650  123456.8020521       015521092.0081015"
     2727230:RBE3, 17114229, , 15008650, 123456, 0.802052, 0, 15521092, 0.0081015
      Expected COMPONENT numbers, found  INTEGER (0).
    Field #7 is the 7th collumn in your RBE3 card, inside your .fem file.
    If you take a look at the OptiStruct Help for RBE3, you will notice that the field #7 relates to your DOF of some of the independent nodes of your RBE.
    It is expected to be something like 123, 123456 pointing to the DOF of your nodes.
    Go to your HM, 1D>>rbe3 panel, review your rbe3 elements listed in the .out file and update the DOFs accordingly.
    OP
    Hi,
    Thank you I definitely look into that and it makes a lot more sense now.
