How to use the python script in Flux 2D
Hello
I have found the Python script file for my simulation in flux 2D, but i want to know if it is possible to execute the code script by script to generate the model in flux?.. For example, someone without the design can easily use the python script to generate the model and all the test that was carried out. is that possible ? and if yes how can i do it ?
thank you for your assitance
1 - 1 of
11
Hi Peter,
Yes we can run the python script in Flux 2D. To do this, in Flux supervisor, we need to go 2D>>Python scripts >> select the script from your directory >> Run the script.
Thanks
Karun
