🎉Community Raffle - Win $25
Join and Win
modelcheck fehler t=717 w=1 hyperwork
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hallo
how can i this lösen
1 - 6 of 61
    User: "Simon Križnik"
    Altair Community Member
    Updated by Simon Križnik
    Hi,
    there are no loads and boundary conditions defined. Create them using Utility>BC's Manager.
    There are also no simulation controls defined- use Utility>Engine file assistant.
    After setting up above mentioned items the model should be able to run.
    The mesh could be checked by F10 (check elements:2D) and improved by 2D>qualityindex, as there are elements failing aspect ratio, jacobian and minimum size.
    The model can be checked for errors and warnings with Tools>Model Checker>Radioss block.
    Altair Employee
    OP
    hallo
    thank you i will this probieren
    Altair Employee
    OP
    hallo i have that done but i couldnt done it because i know not mach about Boundry und Gravity Engine.But you are right
    What problem are you currently facing?
    I suggest you go through free Altair e-books, start with  Practical Aspects of Finite Element Simulation and then Introduction to Explicit Analysis using RADIOSS.
    You can learn from learning and Certification program. Please follow below link.
    https://certification.altairuniversity.com/  > (Learn Modeling and Visualisation)
    check the following youtube channels:
    AltairUniversity
    Altair India Student Contest
    ELEATION By Apoorv Bapat
    Altair Employee
    OP
    k
    You can contact me on email
