hallo
how can i this lösen
there are no loads and boundary conditions defined. Create them using Utility>BC's Manager.
There are also no simulation controls defined- use Utility>Engine file assistant.
After setting up above mentioned items the model should be able to run.
The mesh could be checked by F10 (check elements:2D) and improved by 2D>qualityindex, as there are elements failing aspect ratio, jacobian and minimum size.
The model can be checked for errors and warnings with Tools>Model Checker>Radioss block.
hallo how can i this lösen
thank you i will this probieren
hallo i have that done but i couldnt done it because i know not mach about Boundry und Gravity Engine.But you are right
What problem are you currently facing?
I suggest you go through free Altair e-books, start with Practical Aspects of Finite Element Simulation and then Introduction to Explicit Analysis using RADIOSS.
You can learn from learning and Certification program. Please follow below link.
https://certification.altairuniversity.com/ > (Learn Modeling and Visualisation)
check the following youtube channels:
AltairUniversity
Altair India Student Contest
ELEATION By Apoorv Bapat
k
You can contact me on email
